Boolean Intersection doesn't render, AND doesn't error
simeon_theobald
Member Posts: 2 ✭
I'm stuck as to where I'm going wrong with this. Everything seems to be in order, but this last boolean operation doesn't want to render.
The parts by themselves are fine, but the intersection boolean just refuses to render.
I'm sure I'm probably overlooking something simple, and would really appreciate some help to figure out what!
https://cad.onshape.com/documents/1b51a4090f4863f66bd553c1/v/1b9d56e1a6ead5f68e044f7c/e/2a4583e0752999ce4832a78f
Thanks!
Thanks!
Is this what you are looking for ?
https://cad.onshape.com/documents/dfebda7f7dfd6ee4331e09f2/w/1c0eb61a2ca4db04a8181995/e/647188fec5bcb8ba26f31ce3
https://cad.onshape.com/documents/a27aa79af6666946b781a452/w/96ed940969c629b1f20f5c8f/e/b052a693b7f6620b01427fdc
Boolean intersect behavior:
Intersect as a part of extrude behavior:
Steve - your example demonstrates a number of 'tricks' I hadn't encountered yet, so special thanks for that!
