Need help on how to import Editing logic function from different feature studio
Hi,
I am trying to call editing logic function from other feature studio to current feature studio as shown below. It seems not working & i see nothing in old definition. Please help me on how to import it. Thanks.
export function fromCurrentFS(context, id, oldDefinition, definition, isCreating, specifiedParameters, hiddenbodies) returns map
          fromOldFS(context, id, oldDefinition, definition, isCreating, specifiedParameters, hiddenbodies);
          return definition;
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,260 image
    You need to make sure fromOldFS is declared with an export in the other feature studio and that other feature studio is imported into the current one without a namespace (if the import has a namespace, the same namespace must be used when calling fromOldFS).
  • Kirankumar_ThimmegowdaKirankumar_Thimmegowda Member Posts: 28 PRO
    Thanks for the reply. It solved after initializing the definition,
              definition=fromOldFS(context, id, oldDefinition, definition, isCreating, specifiedParameters, hiddenbodies);
              return definition;
    edited February 2020
    @Kin
    That's because FeatureScript is pass-by-value, not pass-by-reference :)
    https://cad.onshape.com/FsDoc/variables.html
