How do I make a bowl.
miyah_hofer
Member Posts: 42 EDU
I know the revolve technique but my drawing is only 15mm thick and when I want to make a bowl in the inside of my drawing it goes all the way to the bottom and through, I don't want that. How do I fix that? (Comment if you don't understand) https://cad.onshape.com/documents/35489f78ac0e65449d5906bb/w/8f77c589bb3630bee6c5005e/e/a595b97e07f0756247070ece
bruce_williams
Member, Developers Posts: 842 EDU
@miyah_hofer
Are you trying to revolve around the horizontal axis? iI you make a sketch on the front plane and revolve around a vertical axis may give you what you are after.
See example here:
https://cad.onshape.com/documents/d2ee252f97b5f13c881405d0/w/f6b39cf282a38b758fcccd9f/e/3fa4cd678c56c2c906ae503a
www.accuratepattern.com5
See example here:
yes - your model is fine now. You were likely seeing the origin point. Just hide the reference geometry (origin, planes, sketches). And as of today we have the GLORIOUS "shift P" to hide all that in one quick key. WooHoo!!!
