An implementation for qQueryCompoundFilter
MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,064 PRO
I have always been annoyed by the lack of a filtering mechanism for QueryCompoundFilters, so I decided to build my own function to do the job.
Please see the code below (It also requires Query operators, an implementation of which can be found below that code)
export function qQueryCompoundFilter(q is Query, filter is QueryFilterCompound) returns Query
    return q * qUnion(switch (filter) {
                        (QueryFilterCompound.ALLOWS_AXIS) : [
                                qGeometry(q, GeometryType.LINE),
                                qGeometry(q, GeometryType.CIRCLE),
                                qGeometry(q, GeometryType.ARC),
                                qGeometry(q, GeometryType.CYLINDER),
                                qBodyType(q, BodyType.MATE_CONNECTOR)
                        (QueryFilterCompound.ALLOWS_DIRECTION) : [
                                qGeometry(q, GeometryType.PLANE),
                        (QueryFilterCompound.ALLOWS_PLANE) : [
                        (QueryFilterCompound.ALLOWS_VERTEX) : [
                                qEntityFilter(q, EntityType.VERTEX),
Query operators:
// Actually, the + (Union) and - (Subtraction) operators are not needed for this feature, only the * (intersection). I just included them for completeness
export operator+(lhs is Query, rhs is Query) returns Query
    if (lhs.queryType == QueryType.UNION)
        lhs.subqueries = @resize(lhs.subqueries, @size(lhs.subqueries) + 1, rhs);
        return lhs;
    return qUnion([lhs, rhs]);
export operator-(lhs is Query, rhs is Query) returns Query
    return qSubtraction(lhs, rhs);
export operator*(lhs is Query, rhs is Query) returns Query
    if (lhs.queryType == QueryType.INTERSECTION)
        return lhs;
    return qIntersection([lhs, rhs]);
PS: The idea of using Query operators stemmed from this discussion. As an example of their use, see my Australian Beams feature here, where they are used quite a lot. For instance, instead of making a Query by populating an array then using qUnion, I can just start off with qNothing() and then use query += stuff;
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    This looks very nice!  I think it would help to see some example queries with your additions.  I have resisted adding these operators to std so far, but if people feel writing queries that way is more intuitive, I may reconsider.
    Why do you have the
    q *
    in your qQueryCompoundFilter function?  All of your subqueries in the qUnion filter q.
    Great stuff @MBartlett21 . Solutions like this definitely ease the pain of writing queries, though we've yet to find the perfect one to include in the standard library.
    In this case, using qIntersection more commonly is probably going to have performance implications. A qIntersection works by first evaluating both inputs, in their entirety, and then finding common entities. If the two queries are both filters of the same root query, then you save some work by replacing the slow
    qIntersection(qEntityFilter(q, EntityType.BODY), qBodyType(q, BodyType.SOLID))
    with the faster
    qBodyType(qEntityFilter(q, EntityType.BODY), BodyType.SOLID)
    Even if qIntersection() itself were free to evaluate, the second query will be faster. The difference is: qBodyType in the latter is only filtering through the bodies, while qBodyType in the former it's filtering through all entities. The cost of this evaluation won't show up in your * code itself, but later, when that query needs to be evaluated (either directly with evaluateQuery(myQuery) or indirectly with e.g. opExtrude(... myQuery ...)). I don't see a great way of keeping the * syntax convenient while keeping the resulting queries fast (but that fact makes me like the -> syntax from the post you linked even more :wink: ).
    edited June 2020
    I you add a compact inline lambda syntax it would almost solve this problem. We would just unwrap nested construction into a sequence of functions. And this would be helpful for not only queries.
    One of the alternatives to the arrow syntax is an approach from Wolfram Language: they use f(#1,#2, ...)& for inline lambda definition.
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,064 PRO
    edited June 2020
    Why do you have the
    q *
    @ilya_baran
    The reason I have it in there is so that the Query evaluates in the proper order (see the documentation for qIntersection - "qIntersection preserves the order of the first subquery")
    EDIT: Fixed @mention
    Also, another filter that we don't have an implementation for is SheetMetalDefinitionEntityType.
    Currently, to filter by that, we need to get the internal body, then filter by an EntityType, then get the entities in the part.
