Planetary Gear Two Inputs Conundrum (Solved)
aaron_bergman616
Member Posts: 3 ✭
I've been designing a fun toy, a planetary gear with two inputs and one output. I want two inputs to show how this can affect speed on the output. I thought my design was on track, but I cannot get the animation to work.
I don't need the teeth to be perfect, but I know the position of the gears are off since OnShape is preventing two gear ratios from formulating at the planet carrier, which causes "Unable to compute any steps for this animation. Unable to apply transform. Instance(s) may be constrained."
I tried using different mates on the same planet carrier only to receive the same error message.
I've tried combining the gear ratios into one ratio for one mate, but I'm not sure of the actual math. Like dominoes, one misstep, and it all falls apart.
Anyone know how to handle two inputs?
Thank you.
https://cad.onshape.com/documents/ea2173c80cf39e48575b1dc4/w/e7f5887c9cf961bb71610435/e/ecb9fb1452c7839ce02ace6c
Thank you.
The "Ring/Carrier" formula with two inputs is: (24/114) +.2
The 24/114 is for the rotation ring made by the belt added to the .2 for the actual ratio of the Ring/Carrier.
If you changed the top pulley to something larger, causing a 2:1 pulley ratio, then simply change the 24 in the formula to 48 to indicate two rotations of the pulley gear.
https://cad.onshape.com/documents/afef36773400edbb60adf7ef/w/293214089ddddea9f823d1af/e/165a47a6e04f9af368a00b09
