I s support for generating a plane spiral planned?
jeffery_biss697
Member Posts: 2 ✭
I need to generate a plane spiral to act as a guide curve and don't see that it can be done, "spiral" is not in the tools nor is a result in Help. Is support planned?
Optionsandrew_troup Member, Mentor Posts: 1,584 ✭✭✭✭✭jeffery_biss697
Arithmetic or Logarithmic?
At the moment, probably the closest way is via a pseudo-spiral, a chain of semicircular tangent arcs (or quarter-circle, eighth-circle etc, providing successively closer approximation)
You will probably get an answer as to whether plane spirals are on the list for implementation, but you are unlikely to get any timeline from the developers: Onshape features generally get released when they are considered to be "done" rather than according to when the schedule considers they should have been done. What you can do is submit an Improvement Request for users to vote on: items receiving lots of votes tend to get earlier priority.5 -
Optionskevin_o_toole_1 Onshape Employees, Developers, HDM Posts: 565For a perfect Archemedean Spiral, you can project a conical helix into a sketch.
Example:
https://cad.onshape.com/documents/c526017c3b894f329b22c776/w/a189b5aba46e4e78a5fa6ecd/e/9474fe11c7f540f4a5752185
9 -
Optionsilya_baran Onshape Employees, Developers, HDM Posts: 1,175Creating a real Archimedean spiral is not too hard: https://cad.onshape.com/documents/c7635269c92d41b8ae8f42e7
That doesn't mean that we wouldn't want "native" sketch support for them where you can constrain it and say dimension the pitch etc., but this is a workaround.
Logarithmic plane spirals are harder -- not sure how to do them other than what Andrew suggested above...Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc6
Example:
Of course I just had to try a revolved spline in lieu of a cone, in
kevin_o_toole_1's model -
but when "Help" says a helix can only be created on a cylinder or a cone, it's telling the whole truth
(Just thought I'd save everyone else the trouble)
So I contrived a workaround to allow me to create an intersection curve between an Archimedean helix and a witch's hat (revolved spline) .... but I hadn't thought it through properly. I never completed it, because I would clearly have achieved nothing whatsoever. As this graphic should explain (Doh!)
https://en.wikipedia.org/wiki/Golden_spiral
https://www.youtube.com/watch?v=_eTw5lKKzmk
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
https://cad.onshape.com/documents/1608b80541c591177445d86b/w/89574a510d51bbc2d5d2e8ca/e/9816ca6829ca7ef8f8c64561
