Can I reorient the view orientation for "N" normal, align with a line/axis/plane?
Dear all
I have created a tilted plane, through a line on a surface (line/angle) but when I want to sketch on that plane, it is rotated slightly from horisontal, see pictures.
Is there any way I can redefine what is "horisontal" in such a way that I can use "horizontal" and "vertical" constrains and when I draw a square, it is not tilted?
Part : https://cad.onshape.com/documents/a0cfef78c20783ffeef31371/w/0400253d2900febd119ddd1f/e/5ce5ef5a97abab0207095277
Thanks in advance
  • Steffen_Schmidt
    Steffen_Schmidt Member Posts: 3 ✭
    Thank you so much Bruce - That was a clever solution. :-)
  • bruce_williams
    bruce_williams Member, Developers Posts: 842 EDU
    You are most welcome.  Keep on going and post any questions or issues - the forum has a bunch of helpful (& some really advanced) people that I have learned a lot from.
    www.accuratepattern.com
