custom msg for undefined table cell
brooke_spreen
Member, Developers Posts: 115 ✭✭✭
For FS tables, does anyone know if it is possible to replace "Not set" with a custom message/value?
Design Engineer | Anerdgy AG
No, but you can just set all the cells to the value you want.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
Thanks for the quick answer!Design Engineer | Anerdgy AG0
Function to set all undefined cells in a column to a custom value:Design Engineer | Anerdgy AG0
You can set the cell value to TableCellError and it will show as red and have a more detailed message on hover over.
tableCellError("bad value", "Bad value encountered").
Yep, but in this case it's not an error....just a blank value
