How do you set up student access when students have Microsoft acounts?
garvin_yeung
garvin_yeung Member Posts: 2 EDU
I just got access to educator enterprise accounts and need help setting up classrooms and access for my students.  Our students have office 365 accounts how do I set up the accounts for them with one click access
  • Mark_Cheli
    Mark_Cheli Member, Onshape Employees Posts: 15 image
    Hi Garvin!
    What you'll want to set up is a Microsoft SSO provider in your Enterprise settings.  I'll provide some basics instructions below but these two resources will be the most important for you:
    - Onshape Education Enterprise Learning Path
    - Documentation on Enterprise SSO
    The basic steps are as follows...
    1. Login to your Enterprise
    2. Click your name in the top-right and select "Enterprise Settings"
    3. Select the Authentication tab on the left
    4. Click Configure SSO provider
    5. Select your SSO provider from the dropdown and upload the appropriate configuration file
    More information on the specifics of the configuration files and how to configured Microsoft ADFS or Azure AD can be found in the documentation above.
