Set name property of curves with featurescript
George_Anderson
Member Posts: 71 ✭✭
In FS it's currently forbidden to set the name property of a curve (only works with bodies and faces).
However, you can select and rename curves in the GUI, so it seems that this shouldn't be a fundamental issue.
I have a system that needs to generate many curves and then allow the user to select them, and having a name helps me make useful messages, so the default "Curve 1", "Curve 2" is really inconvenient.
We should remove this request. It turns out this is already possible. The "curves" listed in the GUI are actually the bodies owning the edges created by opFitSpline. So you can set the name of the owner body of the curve, and it works normally.0
