Flex in Onshape
amir_livne
Posts: 85 ✭✭
Hi
I'll appreciate if someone can help me
I'm looking for a similar command to "Flex" command in Solidworks
Attached a part I'm trying to build
Thank you
Thank you
I have some tools for nonlinear deformation, most of them are designed to work with curves. We could treat a body as a curve cage which is covered by surface patches, but it doesn't always work, so it's better to see a certain part first.
There is no image in your post, of the part you’re trying to buildamir_livne said:... Attached a part I'm trying to build
There may be an easy enough way to accomplish what you want without having to use a flex type of function
But we would need to see what it is you’re trying to do
there is already a very similar thread about this kind of deformed part:0
Onshape flex features
