How do I use mates/relations to simulate rolling down a curved ramp?
dawen_cheng
Posts: 11 EDU
Hi, sorry if a similar question has been posted before. I'm working on a project where I send a vehicle down a ramp and try to stop as close as possible to a target point decided on the day of the competition. I've created the vehicle I plan to use but I'm still designing the ramp in Onshape.
One possible issue I thought of was the front of the vehicle (a wooden dowel) scraping the ramp due to the extreme "slope/rate of change" on the ramp. I want to know if there's a way to mate the vehicle to the ramp with a slider/planar? It's a curved surface so it's a bit different from similar things I've worked on. If the "mate" is possible, can I animate the car rolling down to check for any interferences (and is there something like interference detection for an animation?)?.
The whole situation looks something like this:
I'd also be open to taking any math-heavy solutions, I know with some geometry and heavy calculus this is definitely solvable. Thanks in advance to anybody who can help out!
"And now here is my secret, a very simple secret: it is only with the heart that one can see rightly, what is essential is invisible to the eye." - Antoine de Saint-Exupery, The Little Prince
To get the general motion down, try using a single curved face. Make the front wheel & the back wheel tangent to that single curved face.
I'm not sure about spinning the wheels or animation if they are tangent to a curved surface.
Edit:
See below.
RENDERCAD
________________________________________________________________________0 -
Try this something like this for the animation: Automated Ramp
- Gear relationship between each of the wheels
- Tangent relationship between the two of the wheels and the ramp
- Planar relationship between the side of the wheels and the side of the ramp, to keep things lined up.
- Tangent relation between the automation rod ant the body
- Gear relationship between the automation rod and the wheels
RENDERCAD
________________________________________________________________________1 -
Thanks for the response! I tried what you did and got up until the automation rod. However, I encountered some errors when doing the gear relationship between the animation rod and wheels.MichaelPascoe said:Try this something like this for the animation: Automated Ramp- Gear relationship between each of the wheels
Do you know why that is and how to fix it? Thanks for all the help so far!"And now here is my secret, a very simple secret: it is only with the heart that one can see rightly, what is essential is invisible to the eye." - Antoine de Saint-Exupery, The Little Prince0 -
I don't see what the problem could be from the pics. If you want, you can link share the document and I will take a closer look. The assembly constraints can be fickle.
RENDERCAD
