Looking for an Animated model of the Geneva Wheel Assembly
jack_aiello
Member Posts: 12 EDU
Hello,
While I know how to build a Geneva Wheel Assembly, I don't know how to animate the assembly. In particular how to set the ratio of rotation between the slotted wheel and driver wheel (with 1 pin)?
Does anyone have a demo that I can play with to learn how to change the settings?
Thanks,
Jack
Thanks,
Jack
Jack, I have the same problem. I have created an eight station wheel with a single pin driver. I can cause the pin using a tangent mate to move in only one slot. I’ve not devised a method of causing the pin to index to the next and subsequent slots.0
