Lofting: Problem with guide lines from a square base to an ellipsoidal shape
derek_vair
Member Posts: 3 ✭
Here's the onshape document URL:
https://cad.onshape.com/documents/9ff53daf0bb504ea1eb7fa44/w/00ca9d592e3ddaeb3ca01cc4/e/cc6f08cdd81203f8d71f968e
The end result is supposed to look like a gravy boat with no handle, and be 3D printable. I have a much larger model that does print, but it gets messed up when I try and scale it down in onshape, and using Cura to scale it down results in walls that are too thin...
Similar to, but unlike the classic "square to circle" that gets twisted, I've got more vertices on the ellipsoidal shape than on the square, as it's made up of an ellipse, with the end of one major axis cut off, and replaced by a tangent line, an arc, and another tangent line (to make a kind of spout). The basic problem is that onshape generates guide lines toward the front, giving an odd shape to the lofted shape. I thought I could use three manually drawn pairs (L & R) of guide lines in the loft - for the rear, the middle/center, and the front of the square, the front being the face of the square closest to the spout.
The rear guide lines work as I expect. However, the center ones don't. I think it's because I can't get the point of intersection of the guide line with the top of the shape to "lock in". A side effect (I think) of the drawing as it is, is that I can't get the shell function to work properly to make the generated loft hollow.
I've tried using intersecting planes, lines drawn on the extrusion face (and then "Used" them in the TrayTopOutline sketch, but can't get a clean intersection point (like I have with the rear guide lines). If there's another technique than loft/ shell, I'd be happy to use it to "step around" this problem.
dirk_van_der_vaart
Member Posts: 561 ✭✭✭
Have a look at this approach,
https://cad.onshape.com/documents/0cb2f0c3a0760634dacf9032/w/899a7f528138072f6d54c2e3/e/51c8fe5c5f4eb85c5ed46ea4
1 -
John_P_Desilets
Onshape Employees, csevp Posts: 267
@derek_vair Lofting sharp and round profiles can be tricky. Often times this will produce creases or folds in a loft. Does the base need to be square? I made a quick example that doesn't have a square base. Maybe this can help?
https://cad.onshape.com/documents/f51be1a8bde220decf0f9476/w/78055e0033e65fdab3f872ed/e/b7ee086adee98a9e74d5714e
1 -
bruce_williams
Member, Developers Posts: 842 EDU
@derek_vair
You have poked the forum team and now you will receive more than you imagined! LOL
Good ideas coming out and you will need to give it the design intent you want.
Here is my quick rough in. Besides the advice @dirk_van_der_vaart & @John_P_Desilets offer, John has also pointed out in past sometimes best to do lofts in smaller sections and I also rounded the rectangle base slightly. This has some crude stuff so hopefully you can refine.
www.accuratepattern.com1 -
dirk_van_der_vaart
Another tip, if a shape is symmetrical, design only half and mirror at the end.0 -
leonid_raiz
Member Posts: 11 ✭✭
I believe you are not taking advantage of all the controls that the loft tool provides. Take a look at my version of your document https://cad.onshape.com/documents/be3fb088f663c6eb8fcebdac/w/3d56ed8c5d7b15683149c62d/e/0530e65ced9558c880e73374
I activated loft Match connections and defined the way how to connect sharp corners at the bottom to intermediate positions on the top edge. The resulting shape is much nicer. I also changed it from surface to solid.
The subsequent shell feature still does not work with your thickness because rear guides are too curved at the bottom; there is not enough room for shell thickness. 1 mm thickness works though. I would also suggest editing TopTrayOutline sketch. The sequence of curves there seems to be changing curvatures too abruptly.0
@John_P_Desilets This approach will work, too, even with my constraint that the bottom part be square - I found a lots of answers to the "loft square to circle" that I can use for that bottom section !
@bruce_williams I'll have to play with the "sectional lofting" technique you used here; hopefully, I'll get it to work for me.
Thanks, all, for your responses.
I finally got to dig into your Gravy Boat model. That is very instructive! Thanks for posting tips and examples like this; I am learning a lot from your stuff.
The edge on this is especially interesting, how you used surfaces and loft settings. Powerful!
Similar to discussion we are having in this thread for reference...
