Linear pattern, snap angle
CaptainBisquick
OS Professional Posts: 33 ✭✭
The linear pattern tool doesn't accept angle input?
You drag the direction arrow away from orthogonal, and an angle input box pops up0
@CaptainBisquick,you can give the angle as below,
1. Drag the square box shown in pattern tool.
2. Give the required angle from reference entity.
1 -
By dragging the direction arrow at the highlighted points as below will move the construction lines at any angle.
You can later provide angle for this construction line which will be an angle input for linear pattern.1 -
OOoops, my bad, I misremembered (angle input box does NOT pop up). I tried to verify at the time, but the computer I was on does not play nicely with Onshape CAD, and I forgot to revisit.0
