Direct access to imported data
juliaschatz
Member, Developers Posts: 8 EDU
It would be nice to be able to have access to image pixel data and access to the raw text of imported files inside FeatureScript, instead of just parsed CSV or JSON data. Parsed XML would be nice too but I'm not holding out.
The impetus for this was working on an SVG import script.
If the file is readable as text (not some binary format), then you can change the file extension to .csv, import as .csv, and then read the csv lines one by one. I did this to write an OBJ file importer.
PS, vote for the feature request here: https://forum.onshape.com/discussion/12409/featurescript-access-to-file-contents
