Whats a good way to size up a shape.
Imhe
Imhe Member Posts: 4
I have a rectangle and want to change the sizes and i have been struggling to find the way to click and size it up. I seem to need to click in a certain order and dont know the order... Thanks
  • wayne_sauder
    wayne_sauder Member, csevp Posts: 669 PRO
    You can use the scale tool, however, I would recommend editing your sketch or extrude that created the object if that is at all a possibility.
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,938 PRO
    edited May 2021
    If the part was created from a sketch, right click edit that sketch from the feature tree on the left side of your screen and edit the size of the part in the sketch.
    Here is the Onshape learning center. It is a great learning resource:
    https://learn.onshape.com/courses/introduction-to-part-design
    RENDERCAD
