How to align boards to at the same length and distance.
parker_rosen294
Member Posts: 4 EDU
Hello, newbie here. I'm trying to model a deck using 8 inch wide planks spaced out by .048 feet (just under half inch) in a sketch. I started by sketching one plank then duplicated it, used the tools to align it how I want. I want to have a total of 15 boards following suit. If there is a better way to do it I am open to all suggestions.
And then used Linear Pattern to make 15 pieces
you’re welcome
