Improvements to Onshape - July 13th, 2021
Lindsay_Early
Lindsay_Early Member, Onshape Employees, Developers Posts: 26 image
edited January 2022 in New in Onshape
We're kicking off July with a new update. This update includes highly requested import and release management features. Let’s take a look!
CAD IMPROVEMENTS
IMPORT IMPROVEMENTS
Split into multiple documents is improved to take advantage of our unique document structure.
https://onshape.wistia.com/medias/aou4g6w9aq
IMPROVED ARRAY AND MAP ITERATION FOR FEATURESCRIPT
Now, define your for loops with the key and value within the declaration:
for (var index, value in myArray)
A similar syntax is allowed for maps as well:
for (var key, value in myMap)
These improvements are equivalent syntax to the existing map/array iteration in Featurescript. See the Featurescript Documentation for more details.
DRAWING IMPROVEMENTS
TABLE SUPPORT FOR ALT + ENTER
Create new lines within a table by holding ALT(Option) while pressing Enter.
GROUP NOTES WITH DRAWING VIEWS
You can group notes and drawing views by pre-selecting them and choosing Group from the right-click in context menu.
https://onshape.wistia.com/medias/j2buyzh8fp
PROFESSIONAL IMPROVEMENTS
RELEASE MANAGEMENT CHANGE DETECTION
Release candidates detect unchanged components to avoid needless revisioning.
https://onshape.wistia.com/medias/rrz0t247xe
RELEASE MANAGEMENT WARNING IMPROVEMENTS
Release Management now detects and warns the user if the candidate contains an obsolete component.
ENTERPRISE IMPROVEMENTS
ANALYTICS IMPROVEMENTS
Analytics has new filters and columns to better organize customized reports and dashboards.
https://onshape.wistia.com/medias/d8l8z76fpz
MOBILE IMPROVEMENTS
SELECTION IMPROVEMENTS IN IOS
Modify the order of selections for Transforms, 3D fit spline, Boolean, and most Mates.
LINK SHARING IN IOS
Activate Share links directly from your iOS device.
For a detailed list of all the changes in this update, please see the changelog.
Remember: The updates listed here are now live for all users when creating new Onshape Documents and over the next few days these features will also be available in Documents created before the date of this update.
  • bruce_williams
    bruce_williams Member, Developers Posts: 842 EDU
    glad to see improvements in import.  Organizing is a big time saver.
    www.accuratepattern.com
  • BenTaylor
    BenTaylor Member Posts: 51 PRO
    Change detection to prevent making unnecessary revisions will be a lifesaver. I've had to make so many individual obsoletions to correct that mistake.
    Ben Taylor
    Lead Mechanical Engineer @ Healing Innovations
  • ian_d_gardiner
    ian_d_gardiner Member, User Group Leader Posts: 35 PRO
    Big improvements to importing and change detection. Thanks Onshape team. New superpowers every three weeks :)
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,944 PRO
    Excellent. Thank you Onshape team!
    Grouping notes will save some clicks.
    RENDERCAD
  • nick_papageorge_dayjob
    nick_papageorge_dayjob Member, csevp Posts: 1,257 PRO
    The import improvement is great! ps, does this make the import tree come in in order, instead of upside down?
  • konstantin_shiriazdanov
    These little FS tweaks are always welcommed, thanks!
  • brooke_spreen
    brooke_spreen Member, Developers Posts: 115 ✭✭✭
    Love the FS 'for (var index, value...)'.....thanks!
    Design Engineer | Anerdgy AG
  • Lucas_Kuhns
    Lucas_Kuhns Member, csevp Posts: 109 PRO
    Glad to see improvements being made on the drawings.
  • Shaun_Field
    Shaun_Field Member Posts: 2
    the imports improvement will be very handy especially if you have A lot of legacy files you need to upload from old software
  • Theo_R
    Theo_R Member Posts: 82 PRO
    Very helpful
    (Would love to prevent a release candidate due to an obsolete PN)
  • danny_payne
    danny_payne Member, User Group Leader Posts: 42 ✭✭
    Really like teh import organizing that is done.
  • karen_wagner223
    karen_wagner223 Member Posts: 30 ✭✭
    The new import feature is awesome. I had an assembly I had to upload that has a cluster of subassemblies in it and it parceled the subs out with their parts in each document. It is so easy to find the items I need to work with in this structure. I'm doing my happy dance!
  • adrian_vlzkz
    adrian_vlzkz Member Posts: 309 PRO
    Love the RM improvements
    CAD Engineering Manager
    I see you have also added opHole() function into the standard library. Found it when faced name conflict with my own opHole function :)
  • 1v4n3rr3
    1v4n3rr3 Member Posts: 2 EDU
    Thanx, great improvements
