New map iteration -- INTERNAL ERROR. Trying to set type of an unbound or captured variable.
George_Anderson
Member Posts: 71 ✭✭
Using the latest Featurescript, I'm intermittently getting this message:
INTERNAL ERROR. Trying to set type of an unbound or captured variable.It always points to various places in my code where I started to use the new support for nicer map iteration:
for (var key, value in myMap){It's happening only rarely, and unpredictably, and seems to reset sometimes when refreshing the page, or switching tabs, so I don't think it is based on different part studio states (like different variable values). I'd file a bug report, but I can't seem to see any pattern, just checking if anyone has seen this.
Even if there isn't a regular pattern, if Onshape seems to be behaving incorrectly, you can/should always file a bug report (and share the document if possible/applicable). That will let the support team investigate document logs that might have more info about what exactly is inconsistent, plus it will be a more direct notification that there is a problem.
Edit: the team is aware of it and it is a priority to fix. The current workaround is to avoid the new for loop syntax.Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
@alnis is my personal account. @alnis_ptc is my official PTC account.1 -
Nothing quite like the inside scoop!
FYI, with the release of Onshape 1.134 this issue is resolved
Feel free to use this new 2-variable for loop syntax any time you iterate through a map or an array!3
