Improvements to Onshape - October 1st, 2021
Ignacio_Martos_
Ignacio_Martos_ Member, Onshape Employees Posts: 18 image
edited October 2021 in New in Onshape
Starting October strong with another exciting Onshape release! Bringing quality of life improvements to drawings, a serious upgrade to link sharing, some exciting Enterprise functionality and new additions to the Learning Center. Let's take a look!
GENERAL IMPROVEMENTS
SET UI, CONFIGURATIONS, EXPLODE AND OTHER FEATURES WHEN LINK SHARING
You can now link share directly to an assembly and view context. This empowers you to share more effectively and spend less time training new view only users on where and how to access data in Onshape.
https://onshape.wistia.com/medias/suim9xy4tz
Link sharing now captures the status of:
  • Show/hide feature list
  • Show/hide instance list
  • Active configuration
  • Show/hide sheet metal tab
  • Exploded/collapsed exploded views
  • BOM tab
  • Show/hide Featurescript custom table tab
  • Active display state
DRAWING IMPROVEMENTS
HIDE LINKED PROPERTY PLACEHOLDER AND BACKGROUND ON DRAWINGS
Previously when adding a property callout in a note a “----” placeholder would show that the callout was not pulling data due to an empty property. You can now hide the grey background behind the placeholder or hide the placeholder altogether until the property is filled.
ABILITY TO "FORESHORTEN" DIAMETER DIMENSIONS
When using the diameter dimension tool in reference to a crop or detailed view we have now added the ability to toggle a foreshortened dimension, adding clarity to the dimension of the diameter being referenced.
ABILITY TO ADD/REMOVE COLUMNS TO THE DRAWING REVISION TABLE
We have added the ability to create a custom revision table, editing Onshape's default revision table. You can now add, remove and reorder columns in the revision table. This new option can be found in the Release Management tab. Both revision and BOM templates have an "All uppercase in Drawings" option now.
https://onshape.wistia.com/medias/k2y3clpqs0
ENTERPRISE IMPROVEMENTS
REMOVING USERS IN BULK USING A CSV FILE
In this release we have implemented the ability to remove users in bulk from an enterprise account. In addition we have improved the user interface when adding or removing users in bulk.
API IMPROVEMENTS
WEBHOOK BASIC AUTHENTICATION AND SIGNATURES
Administrators can now configure webhooks with additional security to ensure all API calls are genuine.
LEARNING CENTER
NEW SELF-PACED COURSES AND LEARNING PATHWAYS
We have several content and platform updates in the Onshape Learning Center!
Master Model Self-paced Course
Learn how to use a master model workflow in your designs by using the Derived feature to utilize master sketches and space allocation parts to drive the design. The new Master Model course is available to Standard, Professional, Enterprise, and Educational users.
Top-Down Design Learning Pathway
Ready to use top-down design workflows in your Onshape designs! This new pathway explores best practices when multi-part modeling in a Part Studio, using managed In-context Design in Assemblies, and the Master Model technique. You will receive a certificate for completing the courses and survey in this pathway. This pathway is available to Standard, Professional, Enterprise, and Educational users.
MORE VIDEO UPDATES
There have been several additional video updates to existing courses in the last few weeks, including a new video on sketch imprinting in Introduction to Sketching, update to the extrude videos in Part Design Using Part Studios and Introduction to Part Design, video updates on the Ball mate in Onshape Assemblies, and a new video on Full round fillet in the Advanced Part Design course.
NEW EVENTS TAB ON THE TRAINING DASHBOARD
Now all live training events you enroll and attend, including the virtual instructor-led classes, are listed on the new Events tab in your Training Dashboard.
ADD YOUR LEARNING CENTER CERTIFICATES TO LINKEDIN
There is a new button on the Certifications tab of your Training Dashboard to easily add your Onshape certificates to your LinkedIn profile!
Remember: The updates listed here are now live for all users when creating new Onshape Documents and over the next few days these features will also be available in Documents created before the date of this update.
  • shawn_crocker
    shawn_crocker Member, OS Professional Posts: 1,047 PRO
    looking good!  Loving the revision table templates.  Never though i needed view specific link sharing until now!
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,945 PRO
    Legit improvements. Thanks Onshape team!
    Link sharing improvements will help communication for sure. The new courses look great too.
    RENDERCAD
  • emagdalenaC2i
    emagdalenaC2i Member, Developers, Channel partner Posts: 867 ✭✭✭✭✭
    En este enlace podéis ver las Novedades de Onshape en español:
    https://youtu.be/zxVKaWbaEKk
    Un saludo,
  • ian_d_gardiner
    ian_d_gardiner Member, User Group Leader Posts: 35 PRO
    Great job! Link to specific view is fantastic!
  • Alex_Pitt
    Alex_Pitt Member Posts: 77 PRO
    edited October 2021
    Great improvement to link sharing! The example in the video is a good one. Assembly tab with active exploded view and BOM tab open. Very useful to share with non-CAD users in procurement or production. Pure magic!
  • Theo_R
    Theo_R Member Posts: 82 PRO
    This is huge.
    Good drawing improvements as well.
    Thank you!
  • Aaron_Magnin
    Aaron_Magnin Member, Onshape Employees Posts: 122 image
    ¡Esto es fantástico! ¡Muchas gracias!
  • emagdalenaC2i
    edited October 2021
    @Aaron_Magnin Tenéis todos los vídeos de las novedades desde la versión 1.52 (14 de Septiembre de 2016)
    Aquí la lista completa
    Un saludo,
  • michael_zeagler204
    michael_zeagler204 Member Posts: 8 ✭✭
    This is all great stuff but drawings have been missing external threads for a long time. If memory serves it's been an improvement request for years.
  • danny_payne
    danny_payne Member, User Group Leader Posts: 42 ✭✭✭
    Love the improvements being made to the drawings. The Rev Table improvement is great. I also really like the training updates.
