Set a color to the holes with cosmetic-thread
Marco_19
Member, Channel partner Posts: 3 ✭✭
Hi all.
Does anyone know if it is possible to create a feature-script in Onshape to set a specific color to the faces (red for example) only for the holes with a cosmetic thread created in my part?
Thank you in advance
Sure.
You can add an attribute to the faces in the cosmetic thread FS and then get all the faces with that attribute and change its color.Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común0
