Mobile FeatureScript Challenge!
MichaelPascoe
MichaelPascoe Member Posts: 2,944 PRO
edited January 2022 in FeatureScript
Have you ever been in line at a coffee shop, and a strong urge to featurscript suddenly hits you? It turns out, you can actually write featurescripts on mobile devices!
Objective: Write a FeatureScript only using your cellphone.
Guidelines:
- Only use your phone
- You may import functions if they are a part of your standard process
- New functions for this feature must be written on the mobile device
Tips:
- Use the chrome mobile app. The Onshape app does not currently support the featurescript tab.
- If it doesn't work, try placing the browser in desktop mode
RENDERCAD
  • EvanReese
    EvanReese Member, Mentor Posts: 3,059 PRO
    I don't think I'm good enough with Featurescript for a handicap to be fun  :D
  • MichaelPascoe
    It can be a mini feature =D
    RENDERCAD
  • EvanReese
    Here. I hope you never make me do that again.
  • MichaelPascoe
    That is the best entry I have seen yet! You might actually win this challenge. Mine is taking a little longer than expected. Turns out I need the opSweep to have sweep normal functionality for this feature to work well...
    ___________________________________________________________
    Project scope line here ->  ||             sweep normal, way over here ->  ||
    RENDERCAD
