Screw length configuration
Pablo_Manero
Member Posts: 9 PRO
Axel_Kollmenter
Member, pcbaevp Posts: 436 PRO
Hi Pablo,
check this out: https://learn.onshape.com/learn/learning-path/onshape-configurations
These Tutorials are very short and brilliant
Best regards,
Axel Kollmenter1 -
shawn_crocker
Member, OS Professional Posts: 978 PRO
I also use custom built fasteners. You can see this document to see how I set up mine. I am using a configuration variable to drive the length of the screw. This way, on the fly I can create a length that I didn't think I would need without having to create a new version of the document. Release management creates a part number for it and everything, for me, stays fairly neat.
https://cad.onshape.com/documents/d3ee2bab92a623872bce817f/w/bfa053f689d66fd037f44fe3/e/cef54cf6492dc0272b01008e
Pablo_Manero
Member Posts: 9 PRO
shawn_crocker said:I also use custom built fasteners. You can see this document to see how I set up mine. I am using a configuration variable to drive the length of the screw. This way, on the fly I can create a length that I didn't think I would need without having to create a new version of the document. Release management creates a part number for it and everything, for me, stays fairly neat.
https://cad.onshape.com/documents/d3ee2bab92a623872bce817f/w/bfa053f689d66fd037f44fe3/e/cef54cf6492dc0272b01008eI think that this document is so usefull but it's not what I'm looking for. I wanna have the standard length associated with each metric. For example, if I select M2 screw, I will have 3,4,5 and 6 mm options, but if I select the M3 option, I will have 4,5,6 and 7 mm length options.
dirk_van_der_vaart
Member Posts: 561 ✭✭✭
Why don't you use this featurescript
https://cad.onshape.com/documents/2d7e0a6b68c2039da4221ebc/w/06d0026261b3d9bb908f74a1/e/0af094653d2a12a450c9cda0
Pablo_Manero
Member Posts: 9 PRO
dirk_van_der_vaart said:Why don't you use this featurescript
Hi Dirk,I want to have a screw properties determinate once I import the part in the assembly and with this feature script I must introduce when I insert the screw. In my assembly are many screws with different characteristics and I don’t want to determinate the properties one by one, so that is the reason why this type of feature script is not useful for me. The other problem I have is that I want to have a configuration which only give me opportunity of introducing the standard screws (metric/length/thread size) and not an imaginary one.
shawn_crocker
@Pablo_Manero oh I see. I didn't fully absorbed you first post. I am hoping onshape will add the ability to configure configuration inputs.0 -
eric_pesty
Member, pcbaevp Posts: 2,651 PRO
Yeah I have been missing this functionality too...
The way we handle this is by creating a "master" screw model and derive it into a new part studio for each size (M4, M5, etc...) and create the length table in there.
By doing this way you should still be able to do a "replace" (if you need to change the size) without breaking mates (because the geometry all comes from the same master so faces ID are the same).
Here's an example doc: https://cad.onshape.com/documents/46a326b4a97bd99579866e64/w/98aff52f023b0b23139beb54/e/a699a4775463f98ce0b0d693
Pablo_Manero
Member Posts: 9 PRO
eric_pesty said:Yeah I have been missing this functionality too...
Here's an example doc: https://cad.onshape.com/documents/46a326b4a97bd99579866e64/w/98aff52f023b0b23139beb54/e/a699a4775463f98ce0b0d693Mmmmm... yes, could be a good idea, but we have a lot of types of screws with multiple combinations of metric, length, thread size... with this mode that you tell me, we would have a very big list of part studios to select the screw that you are looking for in the import option...For other examples I will keep your option in mind!
Thanks Eric!0
Axel Kollmenter
Thank you! I will check the videos.
Hi Dirk,
Thanks Eric!
