is it possible to make a circular number pattern? ie. a dial face.
Grompy989
Grompy989 Member Posts: 18 ✭✭
I'm trying to make a 2 digit counter.  I have the design the way I want it, however I dont know how to make a circular pattern of numbers from 0-9.   Is this possible ??
  • Grompy989
    holy hell batman, you even made a video too... thanks for the info.. however the rotation isn't in the correct orientation, and the numbers are not flat to a surface.
    think of a coin.  I need the numbers to go around the face of the coin.  and be 0-9 not 1-9.
    but this vid definitely will be useful for another project
  • Grompy989
    thanks for the info.. I attempted to follow your directions. it did not work.
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,938 PRO
    edited February 2023
    Sure thing @johnathan_oey872. This technique is a difficult one to do. Feel free to share a link to your document and I will take a look. From here, the simplest way to pattern it flat will be to change the orientation of the number.
    To re-orient the number you will need to edit the in context mate connector that determines the text location do this:
    • Edit the Text feature.
    • Click the very small mate button to edit that implicit mate.
    • Change the origin of the mate to the start of the axis line.
    • Set Z to 0.
    • Set Y to whatever you want.
    https://cad.onshape.com/documents/aff472c3def984252e6e3fb4/w/3c972d6084bec1d9fd09e0cb/e/2e0fafe2ffeea1699f698760?renderMode=0&uiState=63ee297b8f9af21504b6b4f1
    RENDERCAD
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,824 PRO
    You could also add a "rotation" transform (rotating by -360/#count) to have all the digits facing "up" if desired.
  • MichaelPascoe
    @johnathan_oey872, I looked at the history of your document and copied it back where you gave it a try; you got very close!
    Here are the things I changed to fix it:
    • Text implicit mate location.
    • Transform angle to 360 / #qty * #count.
    • Transform axis.
    • Pattern qty to use the variable #qty.
    https://cad.onshape.com/documents/11be8f315519c158facf43ad/w/67b4d0efd161e70caadc0944/e/1fe09e3fc77596c4f4f4b5e0?renderMode=0&uiState=63ef74bf708b0b77c6bacd19
    RENDERCAD
  • Grompy989
    FINALLY !!  LOL thanks for the help... Its working now... But now, how do make them look like they are engraved, not raised !
  • dirk_van_der_vaart
    dirk_van_der_vaart Member Posts: 561 ✭✭✭
    Adjust the Z axis in the transform so that the number's in a bit in the green circle and than Boolean substract
  • MichaelPascoe
    @johnathan_oey872, adjust the implicit mate connector location inside the Text feature. Bring it down in the Z; then, after the pattern, use Boolean subtract like Dirk mentioned.
    RENDERCAD
  • Grompy989
    attempted the boolean subtract. It did not work.
    edited text
    Z height direction to opposite
    selected each "part" for each number
    right clicked
    clicked boolean/subtract
    failed to regenerate
    what am i missing
  • Grompy989
    Figured it out by dumb luck....
    I needed to click the "Targets" button and select the part to change in the boolean / subtract section..
  • jmsaltzman
    jmsaltzman Member Posts: 20 ✭✭
    This is amazing! Many thanks, @MichaelPascoe!
    Also (ahem) an old thread, and I found an issue: numbers greater than 9 draw strangely. When I try the example with qty=11, I get this:
    The 0 from 10 is positioned with the first digit, with space for the 1. This seems like an issue with the amazing Text feature (up to date fwiw). I tried to make a clock face, starting count at 0 (vs -1) so the clock face starts counting with 1 in the right position, but it does the same thing with the 0 from 10:
    I've drawn patterns like this previously using a Python script to generate an SVG which I convert to DXF and import. That works fine but THIS method is amazing for being inside Onshape (and for the incredible variable jiu jitsu).
    Any clues would be appreciated. Here's the file I put together, showing my first example.
    S1mon Member Posts: 4,456 PRO
    I would look at "text path". It should solve all of the issues much more quickly.
  • MichaelPascoe
    edited February 2025
    I think sketches can now handle feature patterns with text expressions? So no need for a custom feature.
    Nevermind, I just tried it. Sketches still can't handle this: https://cad.onshape.com/documents/11be8f315519c158facf43ad/w/67b4d0efd161e70caadc0944/e/dd792b0c95a5010725997…
    RENDERCAD
  • jnewth
    jnewth Member, OS Professional Posts: 150 PRO
    There's a simpler way to do this as @S1mon mentioned. Here's a version of your doc that has your dial:
    https://cad.onshape.com/documents/4fd1a079592b7f4a7b788a8e/w/be94444c984ed56c4bd0e526/e/3569728fa430422861c1bbb0
    And you can learn more about the Text feature here:
    https://forum.onshape.com/discussion/comment/101768#Comment_101768
    The doc that contains the Text feature includes a set of Clock face examples. This custom feature distributes text or sequences around a path, including closed paths (so where there's no beginning or ending).
  • jmsaltzman
    @S1mon your script is a dream, thank you!
    And @MichaelPascoe thank you for the expression insight!
