How to sketch atop multiple faces?
josh_mccullough080
Member Posts: 24 ✭
See here: https://cad.onshape.com/documents/7a95e4e5ecc3df14bfe96b68/w/dcc38852fdcd046c79f14ab9/e/f219ea2cea573f2e9dd4e463?renderMode=0&uiState=63f53b0cc392ad69d1d0b795
Note that I have a sketch created from the top face of the circle extrusion. Within that sketch I've drawn the areas shown by the green arrows but I can only extrude the portion of the sketch which is drawn on the circle's face. Also, I cannot trim the back portion of the circle (pink arrow).
Do I have to make 3 separate sketches, one on the circle and then one on each rectangle? I thought I was able to tackle this with one sketch. Thanks.
@josh_mccullough080Different areas of your sketch were not ENCLOSED
You can tell if something is enclosed because there will be a gray shading to show what area is enclosed in a sketch.
I used the USE tool to enclose them. You could’ve also used the line tool at the cuboid projections and the arc tool on the cylinder
Thank you, that helps! It also explains why sometimes my sketches have extra stuff from the face I'm sketching on.0
