Background Color - How Setup to White
elton_petroli
Member Posts: 4 EDU
Hello.
I would you like to share with you an problem about background color from OnShape. How is possible to change the background color black to white version?
I tryed to change the "Appearance" from setup, however the backgroung color do not change to white.
Thank you so much for support me!
Matt_Shields
Member, Onshape Employees Posts: 968 PRO
In Onshape, a black screen indicates that you are having a graphics rendering problem. If you are in Chrome, check to make sure hardware acceleration is enabled:- Go to chrome://settings/
- System
- Make sure “use hardware acceleration when available” is checked.
- Go to chrome://flags/
- Make sure “Override software rendering list” is Enabled.
-1
Your advice solved my issue.
See ya.
