Background Color - How Setup to White
elton_petroli
elton_petroli Member Posts: 4 EDU
Hello.
I would you like to share with you an problem about background color from OnShape. How is possible to change the background color black to white version?
I tryed to change the "Appearance" from setup, however the backgroung color do not change to white.
Thank you so much for support me!
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 1,007 PRO
    In Onshape, a black screen indicates that you are having a graphics rendering problem.  If you are in Chrome, check to make sure hardware acceleration is enabled:
    • Go to chrome://settings/
    • System
    • Make sure “use hardware acceleration when available” is checked.
    • Go to chrome://flags/
    • Make sure “Override software rendering list” is Enabled.
  • Matt_Shields
    • System
  • elton_petroli
    Thanks Sr. Matt_Shields
    Your advice solved my issue.
    See ya.
