FeatureScript TableData not effective.
hervé_pipon
hervé_pipon Member Posts: 60 ✭✭
I write a FeatureScript which has to import a csv file :
export const CSV_Path = defineFeature(function (context is Context, id is Id, definition is map) precondition {
    annotation {
        "Name": "file"
    definition.myPathCurve is TableData;
My problem is that half the time the file is not read
The script starts correctly,
If I click again definition.myPathCurve.csvData == undefined
And on the next click it works .... and so on...
How can I make it works all the time ?
  • Jacob_Corder
    Jacob_Corder Member Posts: 141 PRO
    you are going to need to share an example.
    It is likely that you are not waiting enough time for it to load the data.  To test. just hit the green check box and wait a minute. if you go back in and reload it again and check box makes it work then its a bug.   I suspect your issue is due to not waiting for the loading wheel to be finished
  • hervé_pipon
    edited August 2023
    @Jacob_Corder
    I have both Part Studio View , and FeatureScript Notice View open at the same time.
    When I click  , I can read on FeatureScript Notice a message generated by my code that indicates that definition.myPathCurve.csvData == undefined
    if (definition.myPathCurve.csvData == undefined) { println("Undefined Path Curve !"); return; }
    There is no need to wait more...
  • hervé_pipon
    It's actually a handling error.
    To save time, I leave the selection window open between each test!
    So when I click the 2nd time, it simply deselects the file :/
    But as I'm only watching the FeatureScript Notice ViewI did not take care of this.
    Sorry for this wrong question  :s
