@evDistance, what @ means ?
hervé_pipon
Posts: 60 ✭✭
Hello
When I look at the evDistance function définition in evaluate.fs, there is a callback to @evDistance...
What does that means?
Is the source code available ?
export function evDistance(context is Context, arg is map) returns DistanceResult
var result = @evDistance(context, arg);
@ functions are faster. If calling the function thousands of times, this can make a difference.
See this comment from Jacob explaining more on evDistance vs @ evDistance
https://forum.onshape.com/discussion/comment/88979/#Comment_88979
RENDERCAD
________________________________________________________________________2 -
Any identifier starting with '@' is a FeatureScript built-in. We don't expose the internals of these calls.
We wrap our built-ins in FS functions in part because the results may need some massaging to be more nicely consumable. evDistance itself is a good example.
(Michael is right, though - the function call overhead is nonzero, and you don't always need the wrapper.)2
