Can Someone Take a Look & See if This is Ready to Print - I'm very new
tom_mort
Member Posts: 39 ✭✭
I was able to draw the simple shape, however I need to give the sides thickness, split it on two planes, one so it prints as two hollow parts to snap together and the other to cut each of those two pieces in half so it will fit the bed of the printer. Also I think I have added mating pins.
I don't see how to view it as the various individual split parts, with the mating connectors, etc or as an exploded view.
Here is a link to the part: https://cad.onshape.com/documents/0a5b2247da664a47830f6083/w/dd6a4ceab6cc71d1dba511b1/e/bc29dffb9b6fc837ecc363aa?configuration=List_GO9J4XH6sq98cN=Default&renderMode=0&uiState=658cdac879793c6528a73d60
Thanks
Thanks
You've got a bunch of failed features that don't do anything. Your working features also don't do anything useful. Take a look at this document, the second tab.
https://cad.onshape.com/documents/696ffed8134009cdcf0260c5/v/6768b755b2d4078458f3c3ff/e/b230879f8d96e80c0fa6afa3
1 -
You also said you "drew" the part. But the first feature is an import of a step file. Did you draw it somewhere in Onshape? If so, there is no reason to export it as a step and import it into a second Onshape document.0
