Problem adding flange to a sketch with "corners" -> "collision in sheet metal flat pattern"
jarkko_lietolahti
Member Posts: 2 ✭
Hi,
I'm very newbie with onshape and trying to model my very first thing. Which is farm equipment fasteners. I can do without the small flanges, but would like to learn how to do them anyways.
This public model https://cad.onshape.com/documents/edc77c3d01ded50a502aee2b/w/c9ffb030211edce5d57e07ad/e/1aa16c100752dbaa15292fa8 shows the problem. So i'm trying to create two small flanges on cut outs. It generates to image correctly, but gives error "collision in sheet metal flat pattern".
I made a correction in sketch 1 to give the flange space, you get an error because in production it is not possible withou a gap.
And another tip, allways design with the origin in middle of your sketch.
https://cad.onshape.com/documents/9c12e3844f8648472ac801f3/w/2e591c36e4f4a5038c2bc116/e/053e3cacabe9deda0e02f8b4
