Detailed phases for creating DWG drawings
petri_muurikainen
Member Posts: 2 ✭✭
Hi !
I didn't find the way to make 2D drawing from the 3D Model. There wasn't the button that the tutorial was showing?
Maybe I did something wrong? But What?
I duplicated the tutorial file, modified it as a private model. No success?
Pls, detailed guide or video maybe?
Thanks,
-Petri
Thanks,
-Petri
Optionspete_yodis OS Professional, Mentor Posts: 666 ✭✭✭@petri_muurikainen Onshape has not yet released drawing functionality to the masses. It is being worked on and some folks have access to an alpha version(s). You are not missing anything. Hang tight for drawings.
5 -
Optionsshashank_aarya Member Posts: 265 ✭✭✭I think it is still under up gradation. We will wait till some formal announcement appears in forums.
5 -
Optionspete_yodis OS Professional, Mentor Posts: 666 ✭✭✭Here is the formal announcement https://forum.onshape.com/discussion/1558/improvements-to-onshape-august-31-2015#latest.
Now you can create your 2D drawings @petri_muurikainen
1
