Cannot get this Sketch to "Wrap" to the target face...what am I doing wrong?
john_lopez363
john_lopez363 Member Posts: 143 ✭✭✭
I've modeled this grip panel, using a basic Extrude feature and then a Loft feature remove to get the curvature of the face.  I want to cut a relief of the skull pattern (using an 3D engraving operation) into the grip panel. I need the relief to maintain the curvature profile of the main grip panel (not flat bottomed).
I thought a Wrap feature of the sketch would would allow be to accomplish this...but I cannot get the Wrap feature to work.  When I try the Wrap feature, I can select the Skull sketch as the tool however I cannot select the face of the grip panel as the "Target".
What am I doing wrong?   Or perhaps there is another approach to accomplish this.
https://cad.onshape.com/documents/2fc6e1f640fe0f85fcbc840d/w/66de37f8ea63b439ebb61953/e/490ba852eeca4fb4ca13be6a
