Configuration variables lead to the error: onshape_client.oas.exceptions.ApiException: (404)
Hello everyone,
I get the following error message when I try to export an stl-file with the onshape-client:
Reason: Not found
This error only occurs if the configuration variables have values that differ from the defined default value. There are 5 different configuration variables in the PartStudio. If the first four deviate from the default value but are still in the definition range, the error occurs. The fifth configuration variable can also have a different value than the default value and the export works. However, not every value can be used for the fifth variable either.
If I change the variables in the browser and export the stl file itself, there is no problem at all. So this means that the values that the configuration variables should take do not cause an error in PartStudio.
I don't understand why I can't export the stl file via the onshape client as soon as the configuration variables differ from the default value.
Can anyone help me in this matter?
Many thanks in advance
