Best Of
Re: Using the hole table in a drawing of a composite part
I have the same issue in a welded fabrication that I'd like to use a hole chart for!
Is there a workaround for this that anyone has found or has an improvment request been made?
Re: Why can't you define a mate connector with another mate connector?
It's not the primary purpose of my custom Poly-Mates feature, but it does have that one-line edit integrated into it so you can create mate connectors in reference to other mate connectors. Sometimes I use it to do position copying across assembly contexts.
Re: Improvements to Onshape - March 13, 2026
Please check again tonight (18th) for using inside a sketch.
With the new “use pen input as mouse” preference, I can now do some more things in Onshape in the browser on my iPad, but I can’t seem to double click. Single click and hover are working. Is there something else that I need to change?
S1mon
Re: When it goes down.....
I'm glad my team never had an uptime tracker when I was doing admin work in Solidworks. I can remember multiple events where the engineers were down for hours while I got to play with a botched server update.
Re: Onshape down in all regions
Yes, the service is recovering, apologies for the inconvenience.
Re: Variable display
@_anton Why are we spaced constrained? Can't the auto complete box just be made bigger so it is not longer space constrained?
