Unclickable Configuration Dropdown?
mike_hölscher
mike_hölscher Member Posts: 110 ✭✭✭✭
In an Assembly, when I hoover or click on this part including configurations I get this teasing pop-up with dropdown box.
But it seems impossible to click...
What is going on here?
  • ilya_baran
    The popup is telling you which configuration the part is at.  To change it, right click on the instance and select "Change configuration..." from the context menu.
  • bradley_sauln
    bradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    @mike_hölscher This is to give you a quick view of what the current configuration of that part is within the assembly. If you have the proper permissions, you can right-click on that instance to change its configuration.
    Look at the bottom section of our help: https://cad.onshape.com/help/Content/configurations.htm?Highlight=configuration
    Twitter: @bradleysauln
  • mike_hölscher
    Thanks @ilya_baran and @bradley_sauln for the replies. That was already clear to me :wink:
    The question is, why is this information displayed as a dropdown box? If this is only info for us to look at, there is no point in having a dropdown-box. This little small triangle/down arrow next to the configuration name just begs to be clicked.
    Is this a teaser for a future functionality of easier configuration swapping? It must be, why else would a UX team put a use-cue like that in there...
  • Don_Van_Zile
    Don_Van_Zile Member Posts: 195 PRO
    I agree with Mike's assessment on both counts.  :)
  • mike_hölscher
    Thanks @Jake_Rosenfeld
    Or you can make it work? :wink:
  • Jake_Rosenfeld
    @mike_hölscher
    That would be nice :smile: We'll start by making it less confusing, but making it work is also on our collective minds.
