Reset hole default depth
kate_leipold_rit
Member Posts: 43 EDU
I'm using the hole tool - and I really appreciate all the built in design decisions. I changed a hole depth on a part and it seems to want to hold on to that depth now. Everything I change, still seems to want to keep my thread depth at 1 in even when I change diameters. Can I somehow reset to the default, calculated thread depth in a blind or blind to last hole?
Hi @kate_leipold_rit
If you set the tap clearance and then the hole depth, the tapped depth should respond appropriately. If you would not like to see the thread options at all, you can switch from tapped to drilled or clearance.Jake Rosenfeld - Modeling Team5
