How do I create a point on a nurbs face?
anirudh_nehra
Member Posts: 7 ✭✭
@anirudh_nehra
Here you go:
https://cad.onshape.com/documents/5419394ec0b5f07c5fec63d9/w/335bc58c04c4fe87aecd0a80/e/43a6c7f597e1e0d3064f7ab8
You can add this to your toolbar by clicking the "+" while visiting the document.
Steps:
1) select the face you want to project onto
2) select some sketch points you want to project
3) select whether you want points, planes, or both
The projection will be in the direction of the normal of the sketch plane of each point.Jake Rosenfeld - Modeling Team1
