Change font size of tolerance
Hello,
How can I change font size of tolerances? When I put the tolerance (deviation) to the dimension, characters of the tolerance have the same size like the main dimension.
I'd like to change the font size of the tolerance to half of the font size of the main dimension, because it doesn't look good when the fonts size is equal.
1
It is not possible yet to specify a different size or font for tolerances and the dimension text. It is only possible to change the size or font of all the text of the dimensions
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común1 -
I have created an improvement request for that
https://forum.onshape.com/discussion/10834/specific-size-and-font-for-the-tolerances-of-the-dimensions/p1?new=1
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común3
