Change Measurement Unit
famadorian
Member Posts: 390 ✭✭✭
When I started my document, I started with simple numbers like 9 and 15, but now I need to change them be be 9 meters and 15 meters. I see that they are 9 mm and 15 mm in the document. Is there any way to just convert the unit for the whole document?
You can change the Workspace units
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común0 -
Also you can change the Units in your accounts settings for new documentsUn saludo,
I don't really want to change the units, as mm is my preferred unit, but I want to change all lengths in the document. For example a length of 9mm becomes 9000mm, so that it equals 9 meters0
You can transform --> Scale a Part Studio
Maybe it helps youUn saludo,
You may want to use this transform FS (it works with sheet metal)
https://cad.onshape.com/documents/c3b16080102aca07dc7ebfaf
