How to export drawing to DXF format in scale 1:1
Gumarang_Wicaksono
Posts: 9 ✭
I have a problem about how to export drawing into format DXF, with scale 1:1.
I have been try many times, but always not in scale 1:1.
I use Draft sight to open DXF file.
Please tell me the solution about this problem.
Thank you
Thank you
Are you exporting from a drawing or directly from the face of a part (right click, export to DXF" option)?If straight from the part it should already be 1:1If on a drawing you may have to delete the template so you just have the geometry without the borders and title block.O.S.Business Systems and Configuration Controller
HWM-Water Ltd0
