Connecting surfaces
Dear all,
I'm trying to learn how to work with CAD, but got allways this problem. What do I wrong, that this 2 parts (surfaces) are not connected as the other (blue) site? This gray part should be like the other blue site.
https://cad.onshape.com/documents/db41c8ba5de0895d8e601322/w/c8eade047295dbcafbaffe1d/e/1535b3e1e9a950172ce3be9d
Thank you for helping me!
  • tim_hess427
    tim_hess427 ✭✭✭✭
    It looks like your document is not public, so I am not able to open it and see what is going on. However, there are two things that you should check:
    1. If you are extruding from a sketch to create a new feature that should be connected to the base feature, make sure you select "Add" in the extrude dialog box.
    2. Make sure the "Merge Scope" section includes all of the correct parts that should be connected to your new feature.
    I hope this helps!
  • tim_hess427
    tim_hess427 ✭✭✭✭
    I hope this helps!
  • Hi @tim_hess427 , thanks a lot for your help, this was exactly what I was looking for! I misses this option to add, my mistake was allways to set it up as new! THANKS!
  • tim_hess427
    tim_hess427 ✭✭✭✭
    Glad to help!
