I'm not sure why OS isn't letting me to make an assembly with a part so I can export it as an STL?
caroline_read
caroline_read Member Posts: 31 ✭
edited July 2015 in Community Support
It says that the thing I made is a surface but not a part and ultimately all I want to do is download it as an stl and then 3d print it just for practice.  Not sure where I'm getting lost.
UPDATE: FIGURED IT OUT not sure how to delete this post though...
  • christopher_owens
    christopher_owens Member Posts: 235 ✭✭
    @caroline_read : If you have more that one Part in your Part Studio you can 'right-click' on it in the Parts List then select "Export to STL..." to only export the selected part.
  • caroline_read
    Also, the reason I mentioned the assembly part is because I thought, or am thinking, that if the part is in the assembly studio that it will be more able to be downloaded.  sorry about the weird phrasing.
  • christopher_owens
