How can I specify the number of segments in a circle?
rminke
rminke Member Posts: 1 PRO
I need to have a circle with more segments than the default, so that the circle appears more round and less stepped. I am trying to revolve a small profile (1/4" square) on a much larger radius (44") and the result is not very smooth segmentation.
  • Prachi
    Prachi Member, OS Professional Posts: 262 ✭✭✭
    You can ask for finer tessellation on individual parts or assemblies. The default can be a little coarse at times but keeps display moving along. Finer tessellation left turned on will slow things down as you add parts. It is the graphic that is coarse not the part.
