are there videos on how to use the enclose tool to fix parts broken into surfaces?
Mazie_Houchens
Mazie_Houchens Member Posts: 36 ✭✭
i know i need to use the enclose tool i think to fix one of the parts i imported but im having a hard time finding a video on how to use it..
  • bruce_williams
    I would like to see a 'tips & tricks' session on working with imported parts.
    www.accuratepattern.com
  • jakeramsley
    jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 669 image
    The approach I take is to use an offset plane to bisect the surfaces, add everything to an enclose (which will normally fail), edit the plane distance with final mode on and move until a part is created.  This will let me do a binary search of which regions are not fully enclosed.
    If you are willing to share an example, I can take a shot trying to enclose it.
    Jake Ramsley
  • owen_sparks
    HWM-Water Ltd
