disappearing arc for loft path
darren_mason871
darren_mason871 Member Posts: 44 ✭✭
I'm trying to make an arc on the right plane connecting the center of the circle on the origin to the point in the rectangle. This arc will be used as a path for a loft between the circle and rectangle. I can sketch the arc, but when I tap the checkmark it disappears. What do I need to do different?
https://cad.onshape.com/documents/a984a262106fe68d477aab28/w/8caad5ce8946508dac59c19d/e/4f52a0ed73c7621b277f83f0
