How to join 2 solids?
VicE_s
VicE_s Member Posts: 4 ✭
Hello, I'm making this crankcase cover, the design is composed of the internal symbol and the outer edge that are connected by lines. Here in onshape the drawing is done well (it seems to me) but when I go to put it in care to make the gcode I have the following problem: the lines that connect the symbol with the outer edge are detected as another separate object (see image ), I need instead to be printed together making it a single block. Is this a problem with my drawing or slicer (care)? And how i can resolve it?
Link drawing: https://cad.onshape.com/documents/e442da7de4e34336149a9fb4/w/b846f8ef9e866e5753636367/e/41292d56587e975fc44165c0
Thanks
