Featurescript-Orient a plane
Hugh_Goodbody
Hugh_Goodbody Member Posts: 41 PRO
I would like to draw a rectangle on the end of an I beam. I have found the plane and the points for the sketched rectangle but the plane's axes are not parallel with the edges of the beam.
I have queried the beam edges, Is it possible to rotate the plane so that one of its axes is in the same direction as the queried lines?
  • Hugh_Goodbody
    Perfect, thanks very much!
