Transform feature seem to be not handled by feature patterns
konstantin_shiriazdanov
Look at this sample document: https://cad-usw2.onshape.com/documents/36c3a2445c2d7bffe51dc462/w/7a956eb02702d8b33c436c00/e/2b41f0a8188e76c52dc90165
I created a body, made a a transform-copy and then applied feature pattern to the copy with apply per instance checked. What i expected is that the copy of the copy will be created in the position described by distance specified in linear pattern feature, instead it just ignores pattern distance and creates new bodies in place without any transforms. I checked the code of transform feature in standart library and seem like it has not getReminderPatternTransform() and transfromResultIfNecessary() functions like if it is not supposed to be capable to interact with feature patterns at all. Is it all right with transform feature form your point? because I had to perform this two days investigation when faced that my featurescript with internal feature pattern doesnt work with transformed geometry as expected.
@konstantin_shiriazdanov
Thank you for spotting this. I'm filing an issue to look into it.0
